This is my first post . I have the above motor and have narrowed down the problem with my tilt and trim to the wire harness from what I will call the selenoid to the tilt motor . The problem is no yamaha dealer has the number of this wire harness . It has what appears to be a relay in the harness which is throwing the parts place off.I am thinking it is the relay , or whatever that part is ,that is my problem. Anyone know of the # for this harness ? Thanks
2005 40 hsp tilt&trim wiring
We don't have any listing for a 40HSP model number, recheck model number.
Originally posted by boats.net View PostWe don't have any listing for a 40HSP model number, recheck model number.
The trim relay is listed under Electrical Tab in parts catalog for your model outboard, Yamaha Outboard Parts
Originally posted by boats.net View PostThe trim relay is listed under Electrical Tab in parts catalog for your model outboard, Yamaha Outboard Parts
2005 F40TLRD Yamaha Outboard ELECTRICAL 3 Diagram and Parts
#6 is the T&T relay
What part # are you calling the selenoid?
And what part # are you calling the "relay" hard wired into harness?
I believe , for the sake of our conversation , and because I call part #6 a selenoid and I think Yamaha may refer to part #6 as a relay , I am confusiong you with my terminology . Assuming part #6 is a "relay" I will change my description of the wire harness that has a small black sealed in line box that is on a wire harness coming off the relay.We thought that this small black sealed box was a relay of some type , thus the confusion on our end. Today while searching where all the wires run , off part#6 ( the relay) we found some wires that joined a bigger wire harness that runs towards the front and outter area of this tiller mount motor . We found 3 or4 wires that were just hanginging there with coils of other wires that the installer had in a corner of the boat . It appears that two of these wires , that had open end male connectors some how ,maybe bounced and were now making contact with each other . We are assuming that these two wires green and blue , being the same color of the wires that are on part #6 ( relay) are the up and down control wires for maybe a wire harness that would come from the front of a boat if the motor had been mounted with a console drive boat . After seperating these two wires , the t&t now works . What do you think . and thanks for your assistance .
Originally posted by 99yam40 View PostIf that fixed it then you should be good to go.
Sill confused on the black box though
ÂÂÂÂÂÂ
