Hi,
I just purchased a used 2004? yamaha 40 tlrs. until recently the power tilt switch on the cowling was working on and off. then the other day it stopped working completely. the relay won't even click when when i depress the cowling switch. the trim switch on the throttle trims the motor up and only clicks the relay when depressed down. the trim motor and hydraulics all work fine.
I can replace the relay but i don't want to spend the money/effort if its the switches.
any insights? or suggestions on how to diagnose...
Oh be sure your connections at the switch are good and you can do a simple test with a multimeter to test it as well. I hope this will help you out Cat
