I have a 2001 yamaha 150hpdi that bogs down if you throttle up fast. If you feather the throttle and slowly ease the boat up it will gain momentum and gain top speed. However at any speed if you put the throttle down too fast it will bog down and sputter.
It turns out that two of the cylinders are being flooded with gas compared to the other 4, and the local mechanic believes those two injectors (cylinder 3) are stuck open and need to be sent out and refurbished.
I spoke to another certified yamaha mechanic I know and he said he has never seen the cylinders flooded with an injector problem. Normally he said they are being starved of fuel.
Just looking to see if anyone has had some similar problems.
Bill
Bill
