Hi Guys,
I have a 2002 115 Yamaha XTRA. I am having a problem where the automatic transfer of oil from the remote tank (tank in hull) is not occurring to the engine tank. It will transfer when using the emergency switch. Here is what I have done so far:
1. Tested the SWB with an omh meter. testing each phase of the switch and it appears to be functioning.
2. Replaced the little strainer in the remote tank.
3. Tested the oil level gauge in the remote tank. Using an ohm meter, I cannot get this to change at all, so I know I have at least one faulty part.
however, will that faulty sensor cause the auto transfer to stop working? I know the float deactivates the auto flow when there are only 2 quarters (I believe) left in the remote tank.
Is there ways to test any issues closer to the motor (control unit, SWB based on actual readings, etc). I want to make sure I can get this problem licked.
Also I do not have the Yamaha tach with the oil sensor indicators.
Thanks in Advance.
Joe
Thanks in Advance.
Joe
