Looking for answer/help 2000 200 hdpi Z200TXRY
How many filters are in the high press pump???? Mine only had/has 1
Started this investigation because I blew the hp hose to the star rail. ( found a great place to fix in Baltimore less than 50 $ + s&h new hose is good to 1500 lbs and is stainless braid ) anyway this lead me to pull the injectors thinking that there was a restriction that caused the hose to blow. Sent all injectors to The Injector Man in Naples...Great guy !!!! While they were being serviced I thought it would be a good idea to change filters in the hp pump.. Took cover off pump and voula only 1 filter basket, now because of the design it could not blow out towards the hose/rail as I thought. It maybe could have gone inside the pump the same way that the fuel flows however I don't really think so. So now this leads me back to the question , was there really 2 to begin with? THANKS in advance
Charles
Charles
