I would like to convert my 89 25sf to electric start. What would I need to do this? Part numbers etc... Also if I decide not to convert to electric start I would like to know if the 25SF has a the ability to charge a battery while running. Not a large battery, just maybe a lawn mower battery. I use them when I run yo-yo's. Any help would be great. Thanks in advance.
Converting 1989 Yamaha 25SF to Electric Start
If your engine came with a lighting coil, and it appears it may have; then there will be two wires coming out from under the flywheel, most likely yellow in colour, that are capped and connected to nothing. You will need a rectifier to convert the alternating current produced to direct current to charge a lead acid battery. It's not to difficult to hook up and charges about 80w or 6amps.
Need number 1, 16 and 17 from this link1989 25SF Yamaha Outboard STARTING MOTOR (25E) Diagram and Parts
Everything from 1989 25SF Yamaha Outboard ELECTRIC PARTS (25E) Diagram and Parts
ÂÂÂÂ
