I cant find the Tach for a 1994 130. Everything I find online says 1996 up to 2005. If there is analog and digital Id like both numbers.
My current Tach will not read RPMs. My green light, red light and buzzer work but I dont know where the yellow light wire plugs to. All of the square conncetors were cut off and there are only two wires on the engine. Someone correct me if Im wrong. The green warning lamp is the sensor in main oil tank that says its good. The red warning is in the main oil tank thats says its low and the yellow to the oil reserve to say its low. Would the yellow lamp plug into the four wires from the reserve tank or does it go to the wires from the ten pin harness? I dont have the Yamaha controls.
