200 Yamaha purchased in July with less than 200 hours. Problem occured yesterday.
While traveling at ~30 MPH, the prop suddenly stopped turning but the engine continued to run at an even higher RPM. The engine ran and runs fine but the prop does not appear to be engaged at any thing faster than an idle speed.
How do I check to see if it is the hub in the prop or if it is something else.
