I have a 96 200hp Saltwater Series II Yamaha with 2 batteries, one starting and one accessory with selector/isolator switch. Wondering if there is a way to charge both batteries from one motor. Any suggestions????
Charging Batteries
Seems like I remember reading about some motors having that capability, all you need to do is run the wire, but I do not remember which motors.
May do some forum searching on the subject or go through the ones Rodbolt posted on that subject
We have this selector switch:
PERKO Inc. - Battery Switches - Medium Duty Battery Selector Switch with AFD
If yours is similar, placing the switch in "ALL" will connect your batteries in parrallel and charge both. When *****ing, switching to "2" isolates "1" allowing you to drive "2" near dead without draining "1" so that you can fire up the engine and get home. Once fired up, switching to "ALL" will then charge "2".
"OFF" isolates both batteries and will prevent discharge during storage if a gauge or lamp is inadvertently powered.
Blue sea makes a kit that accomplishes the same automatically. On my boat's forum, it gets accolades.
http://bluesea.com/files/images/products/7650.jpg
Hope this helps, good luck and keep us posted.
BTW, Last Saturday I was returning on the emergency ferry from Rodanthe, Hatteras Island, NC chit chatting with good friend Cpt. Rudy about another's Merc Verado. He noted that near everyone on the Outer Banks runs Yamaha's because they don't like working on weekends.
