I have a 2006 F150 with the extended mid section (located between the lower unit and main mid section-with the longer drive shaft). I did a search but couldn't find anything about the bushing apparently added by Yamaha to help support the longer drive shaft. When servicing the water pump or R&R'ing the lower unit, this bushing MUST be lubed or it will squeel with time.. The bushing itself is held in the case with a circlip, has thin rubber pieces holding/centering the center bushing (that the drive shaft actually goes thru).
Question, has anyone removed this bushing permanently? Any consequences if removed? Obviously, if this bushing is lubed yearly its fine, much longer than that it'll squeel..
Thanks ahead of time.
