i have a 2001 yamaha 115 4stroke outboard, im having a oil buzzer issue,well at cold starts when i start the motor oil light bar and buzzer comes on,this occurs only only cold start,checked the oil levels are all good,id turn key off,on,off,on until buzzer goes off,run motor all day long and motor runs perfect,no smoke,idles good. so does anyone have the same problem? oh and when i changed the oil pressure sensor oil buzzer didnt sound for a good 2 or 3 months,but now it started again.
Need help with oil buzzer!
I agree, 'fix what is wrong" cutting a wire to stop the alarm will be easy, however, if you happen to have a failure later, you will wish you had "dat irritating sound" when faced with a big repair bill! you will need to trouble shoot the system when it is cold (the only time it plays up) how to do it has been covered in minute detail lots of times, so do a search and see what you can do, or take it to a dealer.
ÂÂ
