I have instaloled na new impeller on my lower unit. The water tube goes into the waterpump housing, there are three pieces left, a brass compression ring, a small white(pvc) pipe approximately 1 inch long. There is also a black sleeve insert that will fit into the waterpump housing. I need help as to whyat order these pieces go.
water impeller installation on 1987 prov
