the circuit makes perfect sense.
you however dont.
its obvious you really dont understand voltage.
voltage is simply a measure of electrical pressure.\
current is usually what makes things happen.
voltage does NOT flow current does.
when you plug the red to blue or red to green your simply doing what the switch is supposed to.
make or break the current path.
checking voltage from red to green or red to blue simply tells you the circuit is ok at that point.
from your description, your switch is failing.
you however dont.
