Can anyone tell me what the lights on the front bottom of the engine hood represent? When my motor started running rough i noticed the yellow light went off and the red started flashing.
lights on front of 40hp
Wayne, again, what's your motor?
Yes, it is possible for the oil level sensor to go bad. You can confirm it by removing the sensor from the tank, plug the hole, clean off the sensor & float, then manually operate the float to the full, 1/3rd full, and empty positions. You have to wait a little between settings, and need to perform the test with the "key on, engine not running". You should see the little lights change between red/yellow/green. If you can remove the old sensor, then you can install a new one, being extra careful to route the wires exactly as you found them.
ÂÂÂÂ
