I have a 2000 2stroke LX150hpTXRY. The engine has been running very rich, which causes it to smoke and idle rough. I looked this problem up in my yamaha outboard shop manual. It says that there is excess fuel getting into the chamber through the vapor seperator tank vent line and to inspect the components in the vapor seperator tank.
While I was troubleshooting this problem I found out that my electronic fuel pump is not shutting off after, an alotted time, you turn the ignition key to the on position.
That being said, How does the electronic fuel pump know when to shut off? I know it shuts off via the CPU, but does that get an electronic signal from some other source. How is the pressure regulator, on top of the VST, incorporated into all of this? Does the float inside the VST have any reason to contribute to this problem?
