I am new to this forum. So here is my first post.
I have a F15MSHZ four stroke that constantly needs some TLC. I have cleaned this Carb many times and carry a spare carburetor for the Dinghy motor. I have installed the water separator and store the engine as well as possible. We learned our lesson with Ethanol Fuel. As you can tell- i am a little frustrated with the Engine
This last time I cleaned the Carb. I developed a nasty fuel leak in the bottom of the Carb. This is the plate that holds the Diaphram Assembly. There are no gaskets and all screws are snug. Could there be a problem with the diaphram or a clogged orifice? If i push down manually on the diaphram- even more fuel squirts out. Any help would be appreciated. Thanks
Darrell
Darrell
