Hi,
I have an old yamaha 60 that the tilt and trim is not workin fully on.
It goes half way up then jumps a few times and stops.
It also lowers fine on its own switch and then back up again, but only halfway.
I have had a look at the oil levels in the reservoir and it seems to be full when fully up and supported, however when I tighten the screw back up and lower the engine with the manual override just as it settles at the bottom it sounds as if there's air in there (gurgling).
I am living in Thailand and am a little wary of letting a Thai mechanic loose on it, so any suggestions would be greatly welcomed.
Thanks in advance.
Nige, Bryant
Thanks in advance.
Nige, Bryant
