Hi,
I have a 2000 (UK spec) F30 outboard with no spark at any of the cylinders. I have been trying to find a manual for it but there doesn't seem to be one available in the UK.
Can anyone help me try to diagnose the problem?
I have checked the kill switch and presume the fault lies with the CDI or the generator.
Any help would be much appreciated.
Cheers Kenny
Cheers Kenny
.check the charge coils, a peak reading multimeter would be best but resistance tests are second best, the charge coil resistance is g/w-w/g 660 ohms with a cranking peak V 193 volts loaded. the power coil y/b-y/b should read about 7 ohms with an unloaded peak of about 7v cranking. the pulser coilr/w-b is anbout 300 ohns with 6 volts peak loaded cranking. also trace the kill circuit to the CDI and test it. you may have a kill switch failure.
