For a 2006 F115, is there a fuel filter between the VST and the low pressure fuel pump? If so, what is the part number and how often should it be changed and checked? Thanks in advance.
2006 F115 Fuel filter between VST and Low Pressure Pump???
Yamaha Outboard Parts 2006 and Later 4-stroke F115TXR 68V-1047408 FUEL INJECTION PUMP Diagram
it is number 33
from what i understand they started putting this filter on the motors in 2007, if your motor has it you can see it in the fuel line from low pressure pump to VST...if not you can get a inline filter and install it much cheaper than the cost of that over priced part. note part 9 in the same diagram is a screen/filter on the bottom of your high pressure pump and needs to be cleaned yearly along with the entire VST chamber.
Originally posted by Sparkieboat View Postfrom what i understand they started putting this filter on the motors in 2007, if your motor has it you can see it in the fuel line from low pressure pump to VST...if not you can get a inline filter and install it much cheaper than the cost of that over priced part.
Â
