I have been seeing a few yamaha 4 strokes up for sell at cheap prices. They are claiming the motor runs fine just needs a foot or they had burnt the foot up. I was wondering is a 4 stroke lower unit similar to a 2 stroke?? Mechanically wise. I have repaired a few 2 stroke lower units and are considering getting one of these 4 strokes, unless yall tell me a 4 stroke foot is a night and day difference. I just don't see how it is could be. But I have never owned a 4 stroke so i don't know. Thanks for your help.
4 stroke Lower Units
as far as I know 4 stroke gear cases are the same as 2 strokes..just different drive shafts and shift rods probably. Be careful because just because a 4-stroke cranks up and idles good ..does not mean that it does not have mechanical issues..best to pay $100 for a computer diagnostic print out, from a dealer.
Originally posted by Sparkieboat View Postas far as I know 4 stroke gear cases are the same as 2 strokes..just different drive shafts and shift rods probably. Be careful because just because a 4-stroke cranks up and idles good ..does not mean that it does not have mechanical issues..best to pay $100 for a computer diagnostic print out, from a dealer.
Not sure if a computer print out will tell much on a 40 & 50, but I may be wrong.
Leak down test will give some info on cylinders being able to seal though.
I did not know what HP the motors were at first...A leak down test would be a good thing to do..if they are EFI then they should have a ECU that would produce a print out of everything about the motor..at least I think..I really do not have any motors that small, I mostly mess with V-4s and V-6s..but the computer print out is very handy..but for a $200 motor I may bypass it, and just do the leak down test.
Tooo Good to be true. An Update. I went after both motors and they could not tell me much about them, mechanically wise. So i said if you give me all the numbers off the plate or shoot a pic of it and send it to me I would look them up. Figuring i would come on here and put in the make and model and get all the info. And poof magically they were sold??? Hmmm makes ya wonder huh...
