Can anyone tell me what the hose running into the leg does? It sits in right at front of the leg, just in front of shift rod/ water pump. I have 70Hp 1989 Yam but I am guessing it is not unique to this motor
Hose going into leg??
It is hooked up to a small orifice on the front edge of the lower unit. Forward motion forces pressure on the tube and that pressure translates into speed if you hook it up to a meter. If the tube is cut or develops a leak then water will flow in the orifice and up the tube and leak out where ever it is leaking at. So cap it off if you cut it.
My reason is now laziness, after maintenace on water pump then lining up and re-attaching the foot of the motor forgetting to connect speedo tube, I dont see the point in pulling it back apart to attach a tube that wont be doing anything.
By the way do either of you know if tension on Head and Exhaust cover bolts differs from motor to motor? if not what is the tension?
