I have a 1988 175 hp two stroke. When fishing the ocean going crabbing after a long drive the idle dropped down about 300 rpms to around 500 to 600 rpm's while idleing and then intermittently die due to a low idle. Normally it runs around 900 rpm's. After a couple of trips I checked my oil level which was almost empty in the main tank. I filled it up and the next time I went out it ran perfect. Does anyone know if this has some sort of an alarm function to cause the idle to drop down as a warning to the owner.
Idle problem that corrected itself?
It did not run out of oil. It was an inch above the bottom of the main 2 gallon tank in the front of the boat. Never drained the oil or changed any oil filter if there is one! Like I said, it is running great now. Just curious if the idle would lower it's RPM normally if the main tank was getting low.
Â
