2004 F60 4 Stroke Tilt Trim in op
  • 2004 F60 4 Stroke Tilt Trim in op
    Is there a way to test the tilt trim motor when removed? I have 12vdc on the blue and green wire depending on trim up/down(assume relay is good). Also noticed a circuit breaker in the trim motor....Is there a way to test? I would assume 0 resistance can you confirm? When removed motor can be turned by hand.
    yep 0 resistance what are the brushes like plenty on meat left on them ?
      Brushes
      Yes motor has less than 50hrs
        Trim Motor circuit breaker
        How many AMPS is the trim motor circuit breaker?
