I have a 2009 F115 4 stroke and ordered the analog temp gauge (6y7-83590-00-00) and the temp gauge sender wire harness (688-83591-00). Neither came with instructions on where to install the plug for the sender on the engine or the proper wire hookups.
The gauge has 2 sets of wire harnesses on it, a black and dark blue as one set which I think are connected for the NAV lights, and then a second set; yellow, 2 black wires and light blue. So here are my questions I hope you could help me with:
1) where does the sending unit get installed on the engine?
2) does the dark Blue and black wires connect to the NAV lighting
3) I beleive the Yellow goes to the ignition +12V, Black goes to ground, the other black to the sender black as well as the light blue to the sender light blue
is this right? My service manual shows no wiring details for the analog temp gauge.
