I have a small but anoying problem. Boat idles fine, starts fine and goes good at 3/4 throttle. It is the transition. When you bring up the throttle it seems slugish like it is on 1 or 2 cyl. Then it takes of to 20kts. If you bump the choke when it is being slugish it will take right off "kind of dangerous if your not hanging on" New plugs, cleaned one carb that the needle and seat was stuck on. Pulled all plugs and they all look the same tan colored and not wet. Any ideas. I am leaning towards the other two carbs in that maybe they are slightly gummed up too.
Miss Kate
Miss Kate
