With new water pump and stats my 250 HPDI will pump water out of the pisser while running but will not when flushing. The amount of water coming out while running is less than the other engine but still is a good flow. The engine runs fine and does not overheat.
Is there a bypass when flushing the engine, not running, using the flush hose located on the port side of the engine?
Thanks in advance!!!!!!!!
