I have a 2003 F225 TURB. A few times, i ave been running in and the motor would act like it lost prime. I reprimed bulb and took off again. Recently While idleing or *****ing for a few minutes, the engine would die like it was out of gas. I changed everything between my fuel tank and the low pressure pump.
When it starts to die, the low pressure pump comes on, but just after it starts to die. I've cleaned the pump and it runs on 12v fine. When I turn my key on, I cant hear it prime. It doesn't spin until I turn the engine over.
It's an expensive pump so I need alittle guideance before i spend the cabbage. Also the engine seemed to be backfireing thru the butterflies when I reved the engine up a bit. Any ideas? confused:
