The tachometer is not reading correct.
When the motor is turned off, it still reads between 1000 and 2000 rpm. When driving this weekend it was way off, it was reading 4000 when going at a slow speed and when I increased speed it was up to 6000 rpm. It is a 2005 motor which I purchased in the fall. I got the 10 hours on the motor before winter, then had the dealer retourq the head change the oil winterize it and whatever
10 hour stuff needed to be done.
Now this is the second time I had it out this year, there is this tach problem and also when I
shift from neutral to forward, sometimes the motor
stalls out.
stalls out.
