last name same as yours ............ YES YOU CAN CLEAN THEM....... I have done it before , are you using E 10 fuel
remember that if you hot wire it you will not have fuse protection ( unless you include one 5 A ) so be careful ....................... if you touch the wires and it does turn give the metal casing part a crack with a 13mm spanner to get the brushes to seat .
also it is not a continuous pump it starts and stops with signals from the ecu
DO NOT use petrol might start a fire
