my small oil tank on the motor fills up and over flows... the big tank keeps pumping even after it's full. i have to cut the power to the big tank, there's a wire i disconnect. i called yamaha parts place and they said there is an oil level sensor that sounds bad.
what i have done (the last couple times ive used it) is connect the wire, let it fill up, then disconnect it again. while driving there is a yellow light on the dash, indicating the big tank is unplugged i assume, it used to be green. when the small tank gets low, the light turns red and i hear a beep. i then shut it down and go thru the process again. that tells me there is two sensors, or maybe not? when the indicator goes red, it beeps and also the motor wont go over 1000 rpm, which is a good thing, i check it often, but it has done it a couple times.
what im asking if anyone has experienced this or may know what it is. the parts guy suggested the oil level sensor but also mentioned the oil control unit? if anyone has advice... ill take it.
thank you, mark rossiter
