Pro Series II Tach
  • Pro Series II Tach
    I repowered with a new 150 txr 2 stroke. A new pro series II tach was installed. The tach has both a temp and oil level warning light. Do these function work with a 2 stroke?
    The two stroke engines requires a 6Y5-81950-00-00 adapter relay to make oil light function properly on a (6Y7) Pro Series II tach.
      Thanks. How can I tell if this adapter relay was install. Where is it located?
        It will be install between tach and harness that goes to motor.
