2002 90 HP Yamaha power trim does not work. Power trim fluid level is OK and I can hear the power trim pump activate when the up / down switch is activated at the motor & driver seat. I have been advised that this motor had a problem with the power trim piston. Any advise would be appreciated.
2002 90 HP Yamaha Power Trim
jarevalo,
The pump has check valves in it that can get stuck if the trim/tilt has not been used in a while. You might try loosening the bypass valve on the pump (your owners manual shows where) and manually raising and lowering the outboard - you might need a little help because you are picking up a couple hundred pounds.
By manually circulating the fluid thru the pump and piston, maybe the check valves will start working properly - it's worth a try. Otherwise you are looking at an overhaul of the pump.
Good luck,
Ken K
