My 1997 150hp yamaha prop keeps spinning slowly while in neutral. Is there some adjustment I can make to fix this?
prop spins while in neutral
It normal for it to slowly spin when running engine, if you can spin prop by hand with engine not running and gear shifter in neutral then adjustment is ok.
It shouldn't be pushing the boat, you might want to check the shift cable adjustment on engine to see if going into neutral.
No that indicates that it is still in gear something is wrong . Check your cable and see if it is centering
ÂÂÂÂÂÂÂ
