Broken Cavitation Plate
  • Broken Cavitation Plate
    Unfortunately I do not have the pictures at this time
    to post. This weekend I ran across what may have been
    a submerged log/etc. I felt a hard hit, and immediately
    throttled back. I have a yamaha f-150 4 stroke 2005 model.
    I was very close to the dock, so I gave it some gas & on
    the take out of the hole it felt different, but otherwise was
    fine. My fishing partner did not feel anything. We did it again
    & this time it seemed okay. Still I had a feeling there was
    damage on either the boat/motor. It felt like a hard hit.
    When I drove the boat onto the trailer, I noticed the damage
    when I tilted the motor out of the water. It knocked a good
    chunk off of the back where it flares out. In fact almost half
    of the zinc anode is exposed. It was probably 5-6 inches in
    length. The prop was okay, and since I did not feel anything
    vibrating I think everything is okay. I still need to check &
    make sure there isn't any water in the lower unit.
    I wonder if they can weld a piece of aluminum or whatever metal
    was on there, without having to replace the entire case on the bottom.
    I am also questioning if they can weld it back with everything intact?
    Otherwise if the lower unit has to be removed & the guts taken out
    I may as well let the mechanic take care of it. Either way I will let my
    insurance company know what happened, and will hold off filing any
    claims until I know more.
    Take it to a Yamaha shop and have them give an estimate, see if your insurance will cover it, that is why you pay the premium. If not then look into trying to repair instead of replacing.
      Update & Question
      I went to the prop shop yesterday, and the owner said he can
      repair the broken cavitation plate. He will have to find a used
      lower unit & cut off the piece that he needs. He said there was
      no way to make a piece that was exact & looked good. When it
      was finished there would be no way to tell it was ever broken.
      Now the other issue was my prop. He said it needed to be re-worked.
      He wanted to know how many rpm's it would turn WOT. When I told
      him 5100 he said that was to low. I have a 19 inch pitch on a 2170
      blazer bay boat. He recommended a 17 pitch. The prop that I got when
      I purchased the boat was a michigan stainless wheel. SO I realize
      the closer I get to 6000 rpm's the better it is for the motor. What
      brand would you suggest? The yamaha props are very expensive.
      Also the yamaha mechanic said IMHO that a re-worked prop is never
      the same. It would be $125 to re-work the prop. The actual damage
      for the cavitation plate was only $250. It seems more prudent to spend
      some extra $$ to get the better prop.
      I did not mention that I had to make an insurance claim a few months
      back when a dead tree fell across both of my boats. It totalled my
      smaller skiff & did some damage to this boat. It was my neighbors tree,
      but still 2 claims a few months apart is not a good idea.
        Your neighbors homeowners insurance would not help pay for his tree damage?
        They can re-pitch props too, if you are sure the motor is running properly you should look at different prop to get proper WOT RPM.
        Have you looked at the Yamaha performance site to see how they did testing a boat and motor like your and what prop they used?
        Performance Bulletin Home
          At this point my insurance company is in subrogation. I am not getting
          my hopes up.
          I did look at the yamaha performance site & there was a boat that
          is somewhat similar. Mine doesn't have a liner & this one did. So the
          weight is probably a bit more. They ran a 18 inch prop. At this point
          I called the blazer factory to get there input.
