1995 9.9 yamaha four stroke
  • 1995 9.9 yamaha four stroke
    hi first post here ,help
    i have a 1995 9.9 four stroke high thrust outboard,
    it starts fine and runs fine for aslong as i want it to run 1-2hours, then after running for any time over 10 mins after i stop it it wont start back up again,if i leave it stand for around 30 mins to an hour it will start again and run fine then when i stop it it wont start again ,
    any help what anyone thinks this could be ?
    i am thinking the cdi unit
    my dad thinks the head gasket but the oil is still clean no sign of water in oil or on plugs,
    anyone help ,thanks jamie
    Check to see if it is getting good spark when not firing up, that should tell you if the CDI or ignition system has a problem. Then it is a matter of compression, fuel mixture and timing that makes it run
