T8 and what control to use
  • T8 and what control to use
    I am putting a T8 remote kicker on my Sylvan Eliminator 1800 and am trying to determine the best way to go as far as control box. Do I go with the 703 side mount or a flush mount? What flush mount is the required unit for this motor? This motor will have electric start, tilt, etc.
    I will be installing this myself and want to make sure that I can make it as smooth as possible. Does anyone have any dimensions on either or both controls?
    Thanks!
    Can use a 703-48207-17-10 side mount control box or
    6X0-48206-12-00 flush mount control box, with flush mount will also need
    704-82570-08-00 switch panel assy.
    your choice of main harness
    6X3-8258A-00-00 16ft
    6X3-8258A-10-00 20ft
    6K1-8258A-40-00 26ft
    61B-8258A-01-00 31ft
    also need two control cables with either control box, MAR-CABLE-xx-SC(replace xx with length cable needed)
      Can you direct me to where I could find the dimensions of the 6X0 control?
