Analog gauge replacment on '06 F150
  • Analog gauge replacment on '06 F150
    I am working on a new dash panel for a customer of mine, and he wants new gauges for his '06 F150. I'm thinking about doing the VDO ocean line, as I stock them, and have had great success with them.
    Has anyone ever used after market gauges for Temp, Tach, Tilt, and possibly water pressure?? Thanks in advance - Joe
    They will work ok. Just get the temp sensor for the gauge you are using.
    You get an adapter that thread into the water pressure port on engine to connect water pressure hose to, it's part number MAR-WPRES-AD-TR.
      Thanks for the quick response... should I use the Mercury trim gauge?? I believe this is the standard now.
        Yes that will work.
