foot removal
  • foot removal
    I need to remove the lower unit from my 2009 225 4stroke. It is counter rotating if that makes a difference. I have removed the 7 bolts and foot doesn't drop. What am I missing? Also I have heard that putting the motor in forward gear eases the reattachment process, is this true?
    did you remove the zinc tab and bolt under it?
      zinc tab
      I did, THere are three bolts on each side and one holding the zinc fin. is there a shift linkage that could be holding it? I removed the cowling on both sides and didn't see any access ports or other bolts. I don't want to force the foot down, but as long as there shouldn't be anything holding it I will use "moderate physical persuasion".
        There are 8 bolts, three on each side, one in front of trim tab and one underneath trim tab.
