I have a '88 90hp outboard. The motor idles like a dream..when I go to apply throttle it opens up great for about 8-10 seconds then dies down to about 1/4 throttle. Ive put a new fuel bulb..line.. tank fittings..new fuel pump...but have no idea what may be the cause.. any help would be greatly appreciated!!
Have a motor issue and need some help
Jason, If problem persists after fuel is checked out make sure all vacuum and oil lines are not damaged or pinched also check temp sensor and oil sensor if you do not premix. If one of these are bad will shut engine down to idle. Coils may also be the problem under a load, you could try disconnecting each one (one) at a time then try to see if there is any difference! Could also be high speed jet(s) if this is a carb model. Make sure this jet and bottom of bowl is clean!Originally posted by jasonak View PostI have a '88 90hp outboard. The motor idles like a dream..when I go to apply throttle it opens up great for about 8-10 seconds then dies down to about 1/4 throttle. Ive put a new fuel bulb..line.. tank fittings..new fuel pump...but have no idea what may be the cause.. any help would be greatly appreciated!!
Hope this helps!!
Bill
Hi,
Good running older motors are a glut on the market and obsolete ones are almost free. Saw an old chrysler with con***** box -a runner- for $150 in the white sheet last week. The ignition alone for that motor is $360. So your cheapest would get a running used merc 85 in the same vintage and hold yours for a spare parts motor.[url=http://www.r4icarte.fr/]linker r4[/url]
