I need help! I have a 2002 F115 4Stroke that loses power when I try to accelerate. I can move under power at 5 to maybe 10mph at 2000 rpms but when I try to accelerate it bogs down and the average top rpms is 3000 and I am still going 10mph. I have taken motor out of gear and am able to get 4000-5000 rpms sometimes and sometimes it will not accelerate past 3000 rpms. I suspect it is one of the power packs at this point. If it is one of the power packs should I change both or just one? Any help will be appreciated. Thanks
This is what I have checked so far:
Changed the spark plugs.
Changed the water separator fuel filter.
Changed the inline fuel filter.
Replace 40 gallons of gas to fresh gas.
Bypassed the water separator filter.
Out of desperation, went to a lower pitch prop.
I have disconnected the lower ignition coil and started engine and engine idles smoothly.
I have disconnected the upper ignition coil and the engine seems to idle rough and spudder slightly.
The engine was running fine in early November and it all started when I fired it up in mid February.
