throttle position sensor
  • throttle position sensor
    Does the the tps adjustment affect the wot rpm's, thanks in advance. regards actionc
    It is possible for it to affect all rpm's.
      tps
      Don't play with the TPS unless you have a computer connected as even setting it back to the old paint mark may be wrong.It makes a major deal with Fuel/air ratio timing,etc.Melted pistons and hot or cold cylinder temps may occur.Good luck and may the Yamaforce Be With You!
