Is there a special tool used to fill the fluid into the PTT reservoir? When I removed the cap there is just a small fill hole.
Adding PTT Pump Fluid
Look like water intrusion killed it. But now two of the bolts sheared off on the gear pump assy when removing motor. Looks like I just went from bad to worse!
Thanks for the tip on filling reservoir.
ÂÂÂÂÂÂÂÂÂÂÂ
