Do small Yamaha motors come filled with gear case oil from the factory?
This is a 2-stroke 8hp, made in France, bought in Florida last winter and run for less than 10 hours.
I just got the motor out of storage to put back on the boat and checking the gear case oil, found it empty. All that came out was a few drips of black water, no sign of any oil. Doesn't even feel oily. Both plugs removed and the ends of the plugs were quite dry, no oil film at all.
No sign of any leakage around the prop shaft or anywhere else and the motor is still like new.
The PDI sheet shows the level was checked and the dealer says it must have had a prop strike and the oil has run out. I'm taking it back in Monday to see what they'll do. I suspect there was never any oil in there and that the black color is from the seals which have probably burned.
What do you think the dealer ought to do? The motor is still under warranty.
