I just trailered my boat back to my house from the camp because I needed to pull my carbs to clean out the low speed jets..... Anyway, put everything back together and the motor runs fine again...BUT I'm not getting a tach reading on my Yamaha Multi-Function Outboard Tachometer. Everything else on the Multi-Function Tach works (hour meter, tilt angle indicator, oil, etc)..the tach just reads '"0"........
Motor is a 2004 Yamaha 90 Four Stroke...
I did not run the boat when I came home, I just proceeded to pull the carbs. I checked all the wire connectors on the motor and under the steering console, everything is good, I disconnected and connected all the connectors, everything is tight.
Should I open the Remote Control Box (Yamaha 703) and if I do what color wires control the tach????
Thanks!!
CatCam
Thanks!!
CatCam
-- No voltage measured......
......unless anyone has one laying around in their spare parts bin!! hehehe
