I have a 2004 yamaha with an intermittant problem....I have invested nearly $2000(including extensive analysis by Yamaha certified mechanics) and they are baffled....
After the engine warms up...you can not exceed 5 mph without the engine konking out...here's what we have done...new plugs, new fuel filter / water filter..( there is no water or contaminant in the gas) rebulit the 3 carbs and (cleaned multiple times including run though an ultra sound cleaner), new thermastate, new fuel pump, ...most recently changed out the pulsar coil ...and then finally the CDI...after the cahnged pulsar coil we thought we nailed it but, after 3 days the intermmitant problem is recurring....I think it is electrical ...when the engine runs it runs well...idles well, you can take it out of gear and rev up to 4000/5000 RPM...but, when the intermmitant issue is occuring (once the engine warms) once you put it in gear and attmept to go more than about 5 mph it konks out...starts righ tup again ...no hesitation....then repeats the same thing...up to 10 or 15 try's and then magically ...will take off....can not help but think this is an electrical issue...because the engine runs and sound great ( when it runs)....one trick ( and I know this is not good and used for emergecny only ) but, when it starts acting up...if I take it out of gear, throttle up then quickly pop it into gear ...it overcomes the issue and takes off.... any body know what is going on.....it does not appear to be the low oil safety...(e.g. if you run low on oil the engine will limit it's speed to 5 mph....that is fucntioning ok....)
And when this issue starts occuring ...the eneigne will immediatley fire back up...but, once in gear can not exceed 5 mph).....we are baffled...not to mention it is getting expensive...even Yamaha after repeated other tests...is baffled...any ideas?????? HELP
