Wanted to spray fogger in the intakes. Couldn't get a bottom screw off the Silencer box. WTF? Tried all my extensions and swivels, NG. Can I just squirt it into the box? Will it make it into the intake or will it just oil the inside of the box? Also, I have twins, the hyd. steering mechanism is in the way of 2 of the grease fittings on the front of the bracket. I can get all 4 on one motor and only 2 on the other. Any secrets for that? Don't want to dismantle the entire steering arm to get on them.
Fogging '06 115
You can fog through the air box and the oil will be sucked into all the internal parts. Fog also into spark plug holes. Maybe you could install some 45 or 90 degree angle zerk fittings so you can grease all the required spots. If you have to loosen or remove the steering then better to go ahead and do it. Good Luck!
