remove prop shaft housing???
  • remove prop shaft housing???
    I can't figure out how to remove the prop shaft housing on my 225 yamaha
    lx225txrz. are there any tricks or tools to removing this?
    Prop shaft housing
    Take the lower unit off motor
    pull off water pump clear too the drive shaft bearing
    pull off shift shaft
    take off two bolts on retaining ring
    take off two bolts on bearing retainer
    might need puller to take off bearing carrier
    shaft should pull out
