Cleaning your Carbs - step by step
  • Cleaning your Carbs - step by step
    I'm a rookie to this and I will like to know if there is a step by step procedure to start cleaning the carbs.
    I looked at past posts but did not find info.
    I have a 1991 225 txrp
    Thanks!
    iam a rookie to and did it in 1 hour. just get you tools and go for it. my motor is a 1990 175 two stroke, should be the same. It's pretty simple. Have a air to comple the project, i took all the screws i saw on each carb one by one, and took the jets (they were all clogged). make sure you do one at a time and leave them as clean as possible. my engine wouldn't idle and ran very bad stalling and missing. Now it runs great lots of power and starts right up.also make sure the float is in good cond. Buy a kit if they are real bad. I didn't but my float looked to be o.k.
      Alex,
      Thanks for your info, I'm planning to do this on Thursday since the weather here in NE is going to be great!!
      what you used as carb cleaner, any recommendations on products?
