Can someone help with the timing specs for a 2004 25 hp four stroke tiller steer motor? The motor idles smoothly, but seems to backfire from the carb when you goose it. We set the timing by centering the timing marks at 0, then lining up the red timing ticks and slipping the timing belt back on (my interpretation is that this is 0 degrees btdc??). I have searched high and low on tricks for setting the timing on this motor, but with no luck. Any help or advice is surley appreciated.
25 hp four stoke timing question
