adapter oil tank & tach wiring
  • adapter oil tank & tach wiring
    I have a 2002 lx250tura, my old harness doesnt match up to the oil tank.(round end) need square adapter need part #.
    and my tach wire has 4 seperate wires that need to go to a square connector on motor too, need part # for adapters 3 female wires , 1 male Thanks
    There are adapters available but if you have a digital tach the trim gauge will not work with newer engine, the tach will read rpm's and oil level indicator will work.
    Adapters are
    6R3-82541-00-00 oil tank adapter
    6R3-82541-10-00 Oil level adapter
    6N7-82541-10-00 trim sender adapter(wouldn't make trim gauge work)
    New tach is part number 6Y5-8350T-82-00 and new harness is 68F-82553-90-00 for the 2002 motor.
    New oil tank kit with harness is part number 6YR-W0035-92-00
      Thanks, need part # just the oil tank harness, have oli tank
        The oil harness for 2002 engine and 2002 oil tank is part number 6R3-85721-80-00(square connectors).
